Ir para o conteúdo principal
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
Controller keeps disconnecting from PS4
It's been 2 months since I bought this controller and it keeps disconnecting from the PS4. Though it was an overheating issue on my PS4 but my older controller works completely fine. Tried resetting it but didn't work, please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
How is the battery? Does it work when you just leave the cable in?
Could be the battery which is broken, could also be something on the motherboard. Depends on if it stays on or not.
Esta resposta foi útil?
Pontuação 1
5 comentários:
Thanks for the reply. The same thing happens with the cable in but It charges fine tho
por
My pleasure! Ah yes, then it's probably the bluetooth IC causing issues there. You can replace the IC. Those are available at AliExpress, you can also replace the motherboard to get it fixed!
por
Thank you so much for the help, sucks to have issues on a new controller
por
My pleasure! Is it completely new at the moment? If yes, you should have it fixed under warranty! Then you will get a new one.
por
Gear Up For Future Repairs
Shop all
Adicionar a sua resposta
Wave Dave será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 72
