Ir para o conteúdo principal
The Canon EOS 40D is a 10.1 MP digital single-lens reflex camera released in August of 2007.
15 Perguntas Visualizar todos
My camera does not turn on
Hello, I’m Chris. My Canon 40D is not powering on except for the print share button that illuminates blue. I have changed both batteries CR 2016 as well as the main battery. I am at a complete loss please help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Does the rear screen alter its color slightly when you turn the camera on?
You might want to take a fresh pink pencil eraser (still soft) carefully wiping the battery contacts both the battery and socket contacts. If I remember correctly you can also power the camera externally via a special cable, does that work?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Chris será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 73
