Ir para o conteúdo principal
O Motorola Atrix 4G é um celular com sistema operacional Android e processador dual core, fabricado pela Motorola. Número do modelo: MB860.
Water damaged.
I dropped my motorola atrix in water. I immerged it in grain rice all night after taking the battery and sin card out, immerging them in rice as well. When I turned on the next day, as it did turn on it says
modem did not puwerr up (1)
Starting RSD protocol support
Battery is too low to flash
Tell me please do I have any chance to have this phone working again?
Please help.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
You need to clean it to avoid further damage
Take the phone apart and soak the motherboard in isopropyl alcohol, and scrub it with a toothbrush GENTLY to loosen dirt, do this for a hour, but disconnect the camera first
Put the phone together and reassess the situation, and tell us what you see so we know what else needs to be done
Also, it's a good idea to buy a new battery because the old one may have shorted out from the water
Electronics Water Damage
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Eva será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 1,823
