Why is my laptop not turning on
My lapotop is not working it's not turning on what should I do
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Well I will suggest you to check out the following thread: https://answers.microsoft.com/en-us/wind...
Esta resposta foi útil?
Does the charging indicator light up when you're charging? If it does, press the power button, then press the capslock and numlock check if they light up. If they do, you may have a problem with the screen.
(Use a USB keyboard, if available, can make it easier to spot the LED indicators)
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 116
1 comentário
I don't know
por Hamza Mearuf
