Ir para o conteúdo principal
Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
20 Perguntas Visualizar todos
Need help! Hoping someone's able to help this old repair tech!
Ok so I'm a certified electronics repair engineer and have worked for Geek Squad repair tech team for 5 years fixing the hardware itself and I worked 1 year for Ubreakifix, 25 years self taught tech repair so im well versed at this point, but....this Apple Watch series 3 I am blindly having problems. I have an apple watch series 5 that had a lock screen when I got it and I managed to do a day 1 factory restore and it works fine.... so anyway the series 3 watch I have , had im assuming a critical software update it was in the middle of and I figure that it failed at some point, so the issue im having now is once the watch is on the charge and the watch turns on it gets stuck in the apple boot screen and just stays there till I keep the watch off the charger and let it die... I've tried the reset option of holding the power button and digital crown down till its supposed to reboot and that's supposed to factory reset it???? IDK apple watches are kinda new to me so can anyone give me some advice a list of things to try??? Like can I use my mag charger to connect it to my PC'S iTunes and reset it there?? I really need some help and I'm a tech of over 25 years but even a great Repair Tech needs a Lil help sometimes lol
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sorry, you need to use your iPhone as it offers the needed application, there is not Watch App under either the iPad or Mac systems.
Now, even still there is a hidden port on the watch where you can interface via a physical connection Vs Bluetooth/WiFi one normally accesses the watch once you’ve tied it to your iPhone. If you take off the strap you can see the small cover in the well. But you do need the special interface to gain access.
From what you describe it sounds like the iPhone it’s linked to is not available as it’s trying to get the files from it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Andrew Derosa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 10
Duração total: 43
