Ir para o conteúdo principal
The Fitbit Versa 3 is a smartwatch released on September 25th, 2020. It features a larger display and built-in GPS.
Why does my replacement battery not charge?
I have now replaced the battery in my Versa 3 twice with an iFixIt product. Twice now I have followed the instructions and successfully insert the battery(s) and proceeded with the charging instructions. Both batteries have charged to 100% then they quickly drain to below 36% and when connected to recharge say the battery is too cold to charge. Is this something anyone has been able to remedy?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
It has powered on with 2 separate replacement batteries, but continues to drain quickly and slowly charges with a "cold battery" warning.
por
Adicionar um comentário
1 resposta
Has the Versa 3 powered on? If it doesn't you may need to see if it is an internal issue.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
J Spence será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 176
