Ir para o conteúdo principal
Brief one or two sentences with identification info. Example: Released June 2009, identified by model number A1303.
How to replace the keyboard
Is it possible someone could give a step by step guide to replacing the keyboard on it?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Adicionar um comentário
1 resposta
Pergunta mais útil
There are a number of Youtube videos on disassembly - search "Acer Nitro 5 AN515-43 disassemble". I haven't viewed them so youo will need to do that and see what works for you.
You won't need to do a complete disass. Ususally the top plastic needs to be removed and a few screws on the bottop holding the KBD. If you are lucky, you won't have to remove the plastic.
Esta resposta foi útil?
Pontuação 1
1 comentário:
My model is 515-42. I was replacing the keyboard twice. And some keys work fail. I don't know what can I do...
por
Adicionar a sua resposta
Break Blocksz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 33
Últimos 30 dias: 109
Ao todo: 1,104
