Ir para o conteúdo principal
The Dell G15-5510 stands apart from the 5511 by its 10th Gen Intel 10200H processor and GeForce GTX graphics. It hosts a wider range of ports, and it built with a sleeker design without sacrificing much performance.
Wire in the way of 2nd SSD slot
I'm planning to put an M.2 2280 in the 2nd SSD slot, but there's a wire in the way of it. Where's a good place to put the wire?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Can the m.2 go over the wire? If not, then I would just peel the tape attempt to route it around the drive. It looks like it has enough slack to go around the end but only you could verify. Look at the attached picture for what I mean
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks for the advice. I put it in today and it did go over the wire without any sort of bend or trouble.
por
Adicionar a sua resposta
Tufty 13 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 79
