Ir para o conteúdo principal
Released September 20, Apple's flagship 2019 smartphone features a 5.8" OLED display, a triple-lens rear camera, and greatly improved battery life. Successor to the iPhone XS.
Tap to wake function not working after screen replacement
Just replaced the screen on my iPhone 11 Pro with the OLED screen kit from ifixit.com. Everything on the phone is functioning perfectly except for the tap to wake function. I've checked and it is currently enabled in the settings menu. Just wondering if this is a recurring problem with these replacement screens.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Were you able to fix this? I’m having the same issue.
por
Adicionar um comentário
2 respostas
Solução escolhida
It is a recurring problem with some replacement screen , contact the support team at iFixit and ask if the function should work with the screens they sell, if it is the case ask for a warranty replacement, if not you are stuck at this point.
Esta resposta foi útil?
Pontuação 2
Gear Up For Future Repairs
Shop all
Hey, it's great that you replaced the screen on your iPhone 11 Pro! Sometimes, after a screen replacement, certain functions may not work as expected. It's possible that the tap to wake function is not fully compatible with the replacement screen. You could try restarting your phone or even reinstalling the screen to see if that helps. If the issue persists, you might want to reach out to the customer support at ifixit.com for further assistance.
Pontuação 1
Adicionar a sua resposta
Steve93 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 116
Ao todo: 1,458
