Ir para o conteúdo principal
The PSP 300x was released in the U.S. on the 15th of October 2008. Repair of this device requires only common tools.
20 Perguntas Visualizar todos
PSP 3001’s Won’t Turn On, but the Battery Heats Up
I bought a used Psp off of ebay to repair it. It didn’t come with a battery so I bought a replacement with the correct voltage. After fully charging battery and placing it in psp, I turned it on. The psp begins to heat up, but the console still doesn’t turn on. What can I do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I would recommend getting a replacement battery. If the battery is heating up it could also be a possibility that there is gas forming in your battery which will cause bloating. For your safety I would recommend removing the existing battery and try purchasing a replacement one.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Extermz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 142
