Ir para o conteúdo principal
A redesigned Pathfinder went on sale in late October 2012 as a 2013 model. Just like the second generation Pathfinder, it once again moved away from a body-on-frame, truck-based SUV and adopted a unibody design.
12 Perguntas Visualizar todos
4WD error: see the owner 's manual; after changing brakes
I have the error mentioned above after changing brakes. The car still drive but can't use 4WD. The light for ABS, traction control and "!" are on. How can I fix this? Nissan Pathfinder 2014 model
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Just started my ‘14 pathfinder, 30 degrees F, and same error message.
Did you get any feedback of the cause?
por
Adicionar um comentário
1 resposta
@robertdraper @billy62801 common errors are anti-lock brake sensor or 4wd sensor or actuator at fault and will be needing to be replaced. However it can go as deep as the transfer case and 4WD module. I suggest you get it scanned and see what codes it shows.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Billy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 970
