Broken upper case hinge
Will a replacement case fix if wires are damaged or are they included with case?
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
No a replacement case will not come with any wires. The black or blue wire is for the wifi antenna, the white wire is for the microphone. The ribbon cable is for the video. If the ribbon cable is broken you will need to purchase a new LCD, as the cable is permanently attached to them.
Esta resposta foi útil?
Tom, please specify if any wires ARE damaged. Otherwise, just ordering a replacement hinge and installing that will do. The wires are a different story however.
what if some of the wires are damaged? then what?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,962
