Ir para o conteúdo principal
Released in 2011, the Satellite Pro L650 was conceived for the daily light office work which could range from surfing the web to word processing.
10 Perguntas Visualizar todos
Adapter working no power to laptop
I plug in laptop and two front lights blink fast but will not come on
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Try this:
  1. Unplug the charger cord from the laptop.
  2. Remove or disconnect the battery.
  3. Press and hold the "Power" button for 30 seconds.
  4. Plug in the charger cord.
  5. Press power button. Does it come on?
  6. If yes then install the battery.
Has that fixed it? Let us know.
Here is link to the User Manual:
Toshiba Satellite L650 User Manual
Dynabook is the new owner of the Toshiba brand
Here is a link to the Maintenance Manual:
Toshiba Satellite L650 Manintenance Manual
If you have a multimeter check that the charger is outputting 19VDC. If not get a new charger.
How old is the battery? They generally last about 5 years if well looked after. It could be a defective battery.
Esta resposta foi útil?
Pontuação 2
3 comentários:
No this does not work
por
I can’t understand why it’s happening I use it for my shows and it’s in mint condition I take good care of it
por
A rather late response but for others perhaps:
The Satellite Pro L650 was released in 2011 so even if it wasn't used much and was "in mint condition" (all that says is that the enclosure has a nice appearance) it doesn't make a difference as electronic components age even when in storage (remembering storage conditions such as temperature, dust, water, etc.). Doordog problem may just mean a dead battery.
por
Daha sonra ramleri temizleyip slot değiştirerek takın
Pontuação 0
Adicionar a sua resposta
Doordog será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 12
Ao todo: 225
