Ir para o conteúdo principal
The HERO6 Black was introduced on September 28, 2017.
Device is not charging
Hi! I have problem with my Hero 6, It's not charging but It can be turned on by plugging a charger, without charger it does not
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hello @johngilbert9992! Have you already tried another battery? If the battery is failed it might explain why it won't power on without a charger, also, what % does the battery show up as when the camera is plugged in, if any? Thanks! :>
Esta resposta foi útil?
Pontuação 0
2 comentários:
Hi! Yes, I tried changing the battery but nothing change, turns on only if I plug a charger even without a battery inside and its show electrical plug charging indicator i think ^^
por
@johngilbert9992 Ah ok no worries! Have you already tried factory resetting the GoPro? I think there might be a setting somewhere that sets it to only use mains power? Or i could be misremembering, I use GoPros a lot myself, but I use a Hero 9 not a Hero 6. Thanks!
por
Adicionar a sua resposta
jjsoliveres2712 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 223
