Ir para o conteúdo principal
Informações de reparo e desmontagem para o smartphone Nokia G43 5G Android, lançado primeiramente em junho de 2023. Identificado pelos números TA-1573, TA-1581 ou TA-1591.
Why my phone is having charging issues
Hi I am having issue with my phone charger it keeps vibrating non stop when charging it keeps say unable to charge your phone your connection is too slow or you may have a incorrect phone charger please change phone charger that came with this device I bought this phone at Walmart and it came with the correct charger so I don't know if it a company error or a chip issue dose any known how to fix this.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Did you change the cable?
I could be a charger problem.
Some troubleshooting tasks are in order.
Try a different cable.
Try a different charger.
Sometimes, a specific cable or charger is needed.
Of course, it could also be a phone issue.
Substitution is the best method.
Esta resposta foi útil?
Pontuação 0
@emeryhaywa23416 You could also try cleaning out the charging port. Pocket lint can cause charging cables to make poor contact with the port.
Get a plastic toothpick or similar non-metal device and slowly insert it into the port and try to pick any lint out with the port facing downwards.
Be gentle to avoid breaking the pick or damaging the usb port.
Pontuação 0
Adicionar a sua resposta
Emery Hayward será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 19
Ao todo: 534
