Camera does not store picture on the SD card.
Power Shot G7 X Mark II will not save picture on the SD Card. What is wrong.
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
There could be a few possible reasons why your PowerShot G7 X Mark II is not saving pictures to the SD card. Just to get something super simple out of the way, note that the camera is compatible with 16GB, 32GB, 64GB, and 128GB SD, SDHC, and SDXC memory cards. If your SD card is other than this list, it won't work. Troubleshooting tips:
First, I would try a different SD card if you have one available to rule out a corrupted card. If that doesn't work, check the save location setting and any firmware updates. If the issue persists, the camera itself may need service for a faulty memory card slot. Let me know if you have any other questions!
Esta resposta foi útil?
SDcards can get corrupted often. If you have a laptop with an sd card slot, try to read the sd card. Maybe format the card to try to fix it.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 289
