Ir para o conteúdo principal
The Galaxy Watch Active2 is a smartwatch from Samsung Electronics. Its model number is SM-R825, SM-R830, or SM-R835 and was released in August 2019. Repair your Samsung Galaxy Watch Active2 with these guides.
20 Perguntas Visualizar todos
Watch is charging but won't turn on after water damage repair.
I took apart my Galaxy Watch Active2, disconnected the battery and cleaned the inside with isopropyl alcohol after it was stuck in a boot loop from what I assume was water damage. After putting it back together and putting it on the charger, it shows that it's charging but won't turn on when I press and hold the power button.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@jackhardacre just because it says it's charging it might not be. Replacing a battery after water damage is almost always a must do. Of course, double check your work too and make sure everything is connected as should. Ultimately, it could also originate from the water damage having created a short circuit somewhere on the board.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jack Hardacre será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 299
