Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
What to do with old MacBook 128GB SSD
I upgraded my MacBook SSD thanks to you and your community who gave wonderful tips and videos, but now I have 2 old SSD 128Gb from 2 old macbook. I want to know if this SSD from old macbook can be used as PEN drive or External SSD drives.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
To use these SSDs as external drives you would need an USB adaptor or a compatible enclosure. You can find an example of one here: External SSD Enclosure for Select Mid 2013 to Mid 2015 Macs
Imagem de Use the SSD originally installed in your Mac as an external drive in this enclosure. USB 3.0 transfer speeds up to 500 MB/s
Produto
$99.99
Esta resposta foi útil?
Pontuação 1
2 comentários:
The cost of enclosure is as much as 256Gb original apple SSD in my country. Any other alternative welcome.
por
Not sure of another way to use it, other than to use it to repair a similar model computer that has a damaged or failing SSD. Otherwise I would try to sell it online.
por
Gear Up For Future Repairs
Shop all
Adicionar a sua resposta
Kalpesh Sampat será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 144
