Ir para o conteúdo principal
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
20 Perguntas Visualizar todos
What is this part for?
I’m 13 years old and trying to take responsibility for breaking my Apple watch by fixing it myself.
I have the screen replacement, but this part came out of my watch. I think it is the force touch sensor, but I wanted to double check.
EDIT: My screen replacement is below. It is off-brand.
If possible could I get some help?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
If you review Step 8 in this Teardown of the Watch you’ll see the pictured part is not the ForceTouch sensor Apple Watch Series 4 Teardown
As to what it is would be tough as there is not enough information in the image to gain a sense of scale or understanding the parts construction.
Using the teardown can you see what it is.
Update (03/05/2023)
@ebp049x - OK, was out enjoying the day sorry for not piping up sooner.
The display assembly is made up of a collection of discrete elements the crystal glass, the touch plate, the OLED screen, the backplate which holds the NFC chip.
What I see is a bunch of mangled parts and you still have part of the display assembly attached to the watches body.
You will need to get a new display assembly to fix this. Here’s the guide which also has the parts info Apple Watch Series 4 Screen Replacement
Imagem de Apple Watch Series 4
Guia
Nível de dificuldade:
Moderada
Imagem de Apple Watch Series 4 Screen
Guia
Difícil
1 - 2 hours
Esta resposta foi útil?
Pontuação 0
7 comentários:
It is part of the screen, which is not disassembled in the teardown.
por
That's the touch screen. Don't worry about it.
por
If I do not reapply it or do not purchase a replacement, will anything on the watch be affected?
por
@ebp049x That is already on the replacement screen. Nothing to worry about. Good luck with the repair.
por
I posted an update
por
Exibir mais 2 comentários
Adicionar a sua resposta
Eshaan Bhargav Patel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 146
