Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para Samsung Galaxy A31. Aqui você recebe tudo o que precisa para consertar por conta própria o seu Samsung Galaxy A31.
Problems with calling people
I have Samsung A21. USB C port didn't want to charge most of the time. I replaced this port and it looks it is working but I got different problems instead.
  1. When I'm in the basement I can't call at all. I get error" You are not registered to network".
  2. When I'm upstairs I can call after doing restart but most people don't hear or hear me bad.
I reinstalled sim card. There are no updates needed.
Any ideas?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
I believe either the daughter board is bad or the installation wasn't done well.
on the daughter board you will find the charging port, the audio jack, a microphone and a antenna connection.
The way it sound it would be either a bad installation where the antenna wasn't reconnected and the microphone placement isn't flush where it needs to be. Or the new board itself is the issue.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Today I opened my phone again. I reinstalled antenna, flex cable and usb board. Everything looks the same. The only issue I see is the antenna cable which looks bad at spots where it bends. Maybe wire is broken inside plastic. I ordered new usb board and antenna. If this won't help I have to buy new phone...
I tested my phone a little more.
1. When I'm in my basement I can't call anybody. Error "phone isn't registered with network". I have no internet.
2. When I'm upstairs or outside I can call and I have internet but usually after restart or turning on/off airplane mode.
3. All people says my voice is broken or they hear only parts of what I say.
4. The best voice is on speaker mode.
5. When I open youtube, all videos are gray, it takes upto 3min to load miniatures and descriptions. When I open any movie it plays for a while and then it stop to buffer for long times...
Same thing happens with websites.
6. Wifi works normal.
por
Adicionar a sua resposta
piotr chmiel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 5
Ao todo: 119
