Ir para o conteúdo principal
Repair information for the gear you use to get out and get active.
20 Perguntas Visualizar todos
Removing a Hover-1 Flair electric scooter throttle body?
How is it done? It has been broken and the scooter has an E2 error. The throttle assembly appears to be modular. I see replacement assemblies for sale online. I can remove the throttle button and have confirmed a broken sensor, but getting the old throttle body off has escaped me so-far. 🥴
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Remove the handle bar extension and grip by unscrewing it clockwise. Extra effort may be needed. Using a 3/32" hex key allen wrench, loosen the inset screw found on the underside of the throttle body shroud. Slide the throttle assembly off the end of the handle bar. Using a sharp knife, carefully cut through the shrink tubing protecting the wire lead terminal connections. Uncouple the terminals. Voilà!
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
You mean off the bars? Look around the housing, should be a hole with a grub screw in it.
Pontuação 1
Adicionar a sua resposta
Robert Edward Sheffey será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 188
