Why my laptop is working slow?
my lap work slow the boot take 1-2 min & after that it takes 40s to get prepare system
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
I would try an m.2 ssd it is direcly attached to the motherboard and would be quiker the other idea is to rearange the boot order. This would be done by entering the bios by mashing the esc button until you see the boot options screen the enter the bios and then go to system configuration then navigating to the boot order press enter this will take you to another screen and put the ssd the os is on to the first option.
Esta resposta foi útil?
i can see your problem be the CPU if you look close your processor is Intel Core i7-8550U 1.8 GHz
and the U means "ultra-low-power," they're instead low-power designs made with efficiency in mind. They have lower clock speeds, lesser cores, and more importantly, a very low TDP.
all the other part of your pc is good but you can search for way or solution for your processor to be faster
good luck
I have been having a bit of a struggle with my laptop lately. It’s been running super slow, and it's really affecting my workflow. I'm not sure what’s causing the lag. I’ve tried the usual fixes like clearing cache, deleting unnecessary files, and even running a virus scan, but nothing seems to help. Has anyone else faced similar issues? If so, how did you resolve it?
I’m curious if integrating such tech could potentially help in diagnosing and preventing the kinds of slowdowns I’m experiencing with my laptop. Also, if anyone knows of any specific wearable applications OR tech that can help with laptop maintenance or productivity, I'd love to hear about them.
What are your thoughts on using wearable tech to enhance our daily tech interactions? Do you think it could help with issues like laptop performance, or do you have any other tips to speed up a slow laptop?
Looking forward to your insights!
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 299
Which OS do you have installed? It would help to know if this happened gradually or overnight (any recent hardware/software upgrade?), and whether the system's overall responsiveness degraded as well or it's just the boot times
por Simone
