Ir para o conteúdo principal
Repair and troubleshooting help for the HP Elitebook 840 G2, a 14" laptop computer from HP.
20 Perguntas Visualizar todos
Bugging when plugin charger
Hello guys,
When I plug the charger the laptop is bugging.
I can't do anything. Everything is slow, even the START menu cant be launch.
But when I remove the charger Everything works fine. The problem is also I cant see the battery icon in taskbar and it going off without any notification of battery dischatging.
Please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Try to completely discharge your computer: remove the battery, hold down the power button for 10 seconds, and reinsert the battery.
If that doesn't work, run HP's power adapter troubleshooting tool at https://support.hp.com/id-en/help/diagno...
Third, try a factory data reset to remove any faulty drivers or software that could be causing the glitches.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Gaspard Tryphon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 9
Duração total: 108
