Ir para o conteúdo principal
Dell Inspiron 15 5584, model number: BBY-V3Y60FX, is a laptop with a touchscreen option released by Dell in 2019.
Mouse cursor disappeared. How yo bring back?
I am using Dell Inspiron 15 and suddenly my cursor has disappeared from screen. I rebooted and did system restore but it is not com in back. Please help
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
when you move your finger across the track-pad, do things on the screen get selected like you could click on it while the cursor is gone, or is it just gone, also there is a button in the function row to turn off the track-pad so if you haven't tried you might want to press it
por
No nothing gets highlighted
por
@saima1984 Do you have a USB mouse you can plug in?
por
Adicionar um comentário
1 resposta
Check if there is a button turn off the trackpad. That happened to me once. Try plugging in a USB mouse and triggering the cursor to come back then see if the trackpad works. Hope this helped!
Diode
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Saima será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Ao todo: 5,387
