Lost access to my SSD!
HI again Dan!!!
I have a problem man ...
Remember back in 2020 I opened my iMac and upgraded it with a Samsung EVO 1TB SSD. After I installed it was working ... Swapping logicboards and compatibility between mid 2015 and late 2015?
I moved to another location to work and left my iMac sitting on the table for about 2 years ... I came back for a holiday break and for my surprise the SSD was not showing up on the iMac as before, thats strange because I remember it was fully working and the iMac recognized it in Disk Utility but now it doesn't show up!
Anyway trying to solve this, by mistake, I invoked in Terminal this line "#diskUtil eraseDisk HSF+ mac disk0" thinking disk0 was the SSD... and BANG I erased my internal SATA Macintosh HD drive...
I have two problems to solve now:
To recover my data files from the SATA drive (I have a time machine backup from 2015.. to old) and to put the SSD working back again.
What can I do Dan??
Hope you can help me out on this!
Update (08/09/2022)
Hi Dan,
So I have on my iMac two hard drives:
- SATA internal HDD that came with the iMac - The one that was erased - It was running MAC OSX Catalina
- The Samsung Evo SSD that i upgraded opening the iMac back in 2020 -It is not recognized by the iMac (but it was working in 2020)
I dont know which version of Disk Utility i have used.. basically I have followed a tutorial on Youtube on how to the Mac show the SSD. I did all they said but erased the SATA main drive. I entered in the Mac Recovery mode and used the terminal to give those commands.
From what you've said to recover my files i need to boot from a USB drive but how do it? I mean How can i make the bootable drive?
I have a Macbook pro from 2011 that can help if necessary... And How can i use the Recovery software you've mentioned?
Can I use a MACOSX DVD to boot? I have Two disc one with Snow Leopard and the other with 10.6.6. Will these Disk are of any use at all to boot the machine?
Please guide me what do i need to do in order to recover the files!!
Esta é uma boa pergunta?
You need to use Mojave or newer macOS as the older Disk Utility app can't deal with APFS volumes which is the first point I made under So what happened?? So no you can't use your MacBook Pro using the OS on it to create the needed drive as its still using the older HFS+ version which will not see your APFS volume! And you can't use Snow Leopard or any other CD/DVD as they are all HFS+ based!
To make a bootable USB thumb drive (32GB) first using your MacBook Pro format the thumb drive with GUID and a Journaled file system. Then using your MacBook download from here the needed macOS release (Catalina) How to get old versions of macOS then copy it over to the USB drive and then follow this guide How to create a bootable installer for macOS this will setup the USB as a bootable drive.
You'll want to download Data Rescue 6 onto the thumb drive as well.
Then using it to boot up your iMac system you can then run the Data Rescue 6 app. Don't forget you need to plug in a salvage drive for the app to save the files to.
por Dan
