Ir para o conteúdo principal
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
My monitor turns off and on intermittently.
I bought a used 27 inch Thunderbolt Display 4 months ago, in good condition to connect it to my 2020 mac mini m1 with Monterey 12.4 installed.
For the past week the monitor has been starting to switch on and off intermittently, often but not always when this happens the cable is very hot and sometimes the bottom of the screen too (without connecting anything to the hub this doesn't seem to overheat).
When the problem first appeared I tried upgrading the mac to 12.4 (from 12.3) thinking it was that, although it seems to have only gotten worse since then.
I'm not sure it's the Thunderbolt Display cable's fault that's causing these problems as I've tried using it on a 2011 macbook pro without then using the adapter and it doesn't seem to be causing any problems.
At this point it could be the adapter, like the cable or something else like a faulty component or firmware issue.
Does anyone have any ideas to solve the problem or at least identify the cause?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Surprisingly you can plug in a thunderbolt cable into the displays back ports instead of using the cable connection. I would give that a try to see if the issue is the cable.
Overheating is often a power issue! Either the houses wiring or forcing a bad connection setup.
Make sure you are using the same outlet as your system for the display using a surge suppresser strip or UPS.
One of the risks is bad grounding of the outlets and/or inverted hot (Black) with the neutral (White) wires of the outlet or plugging the device cable into the outlet upside down (broken ground pin or using a three to two blade adapter or using a two blade power cord).
Esta resposta foi útil?
Pontuação 2
3 comentários:
Thank you very much for your advice and warnings about the power supply. I should get the new thunderbolt 2 connector in the next few days, I'll let you know soon
por
@spiderdeluxe - New Cable - Right?
por
@danj thank you very much, with the new cable I no longer have problems with sudden shutdowns.
por
Adicionar a sua resposta
Fabrizio será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 110
Ao todo: 2,580
