Ir para o conteúdo principal
8.0 Megapixels, 3.6x optical zoom, 2.6" LCD Monitor
Is there a way to separate the LCD from the backlight?
Is there a way to separate the LCD from the backlight? My LCD cracked so I bought a replacement. I removed the LCD+backlight combination part and I can't figure out how to separate them. And I can't find either of the other two parts for sale (backlight or combination unit).
Edit: added pictures. In pictures with both LCDs, old LCD+backlight combination on bottom, new LCD on top. It's not obvious from the pictures, but the combination unit is about twice as thick and has 2 electrical plugs (extra plug is for the backlight).
Update (05/23/2022)
I have a replacement LCD display (without backlight). I tried prying the backlight apart from the outgoing LCD and it won't budge. Is there a trick for it?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
I believe (or hope) this video will help, most canon will have the same setup and it looks like your photos. Worth a look, I can't tell for sure,. But that metal on the side looks like the frame on an lcd screen that lets you change the cold florescent tube(s), which fits. Good Luck
Esta resposta foi útil?
Pontuação 1
4 comentários:
@uchetil I believe that the backlight for these screens are actually an LED backlight instead of a CCFL
por
And you are correct, but the remainder of the assembly is (in the one in the video, an 1100D Canon EOS- Rebel T3i / 600d and possibly in the S80 too) the same, diffusion layer, polarizer etc just the light source is different. Hmm, could be I missed your point, I shouldn't. Have introduced a possibly confusing reference.
por
Thanks for the video. I carefully slid a spudger around the perimeter and was able to get it separated. The corners were particularly difficult because the plastic frame is very thin and I didn't want to break it.
The backlight on my model (Canon Elph 330HS) is actually just a thin metal strip (about 4 mm wide) with 4 LEDs in a line and pressed up against a reflective translucent white sheet that disperses the light.
One tricky part is to gauge exactly where to put the spudger. There are several micro-thin layers and you have to look at the new LCD part to see exactly how thick it is.
Anyway, it's all back together and working perfectly. I hope this is helpful to someone.
por
Thanks for the feedback, @stefan_s glad it helped. Since it worked for you kindly 'accept' this answer, thanks and congratulations! Cool! (Dating myself with that I guess)
por
Adicionar a sua resposta
Stefan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 641
