Ir para o conteúdo principal
help did I get scammed?
So i bought this thinking i could fix one of my other ones,
Anyway when it arrived, i plugged it in and nothing,
I thought something was unplugged inside, so I took it Apart nothing was unplugged,
So i tried the keyboard on one of my other laptops, still nothing Nothing
What the heck is going on?
@danj
Esta é uma boa pergunta?
Pontuação 0
2 comentários
What does the onboard battery checker tell you?
por
@danj - By nothing i mean it does nothing at all (black screen, no lights, no fan speed)
por
Adicionar um comentário
1 resposta
Solução escolhida
There is a onboard battery checker within the battery. locate the LED's and the small button on the battery. What do you get?
The charger plug also has a Green or Amber lit collar. Is it lit and what is the color?
If both are dead then you will need to get replacements to check things.
Esta resposta foi útil?
Pontuação 1
20 comentários:
I got no battery,
The charger has a green light
por
@beanman56 - OK, this series needs a battery to run. I would also replace the PRAM battery MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement But how much are you willing to put into this system? What is your expectation?
por
@danj - A decent macbook for media,
Also i like the keyboard design,
Would a 2007 macbook (NOT PRO) battery work?
idc if the matches
por
@danj - where can i get one for a cheap price?
por
Exibir mais 15 comentários
Adicionar a sua resposta
Ben Capehart será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 191
