Ir para o conteúdo principal
Repair and troubleshooting information for the HP EliteBook 840 G5, an HP laptop part of the HP EliteBook series. Released in February 2018.
20 Perguntas Visualizar todos
Why my pc not showing fingerprint unlock?
my pc has finger print sensor, but in settings it is not showing
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @rish , assuming you are using Windows 10 or Windows 11, this is a software problem after some recent windows updates. Indeed I got the same problem, and I have seen similar complaints in the community very recently. So this shouldn’t be a hardware issue.
I fixed the problem reinstalling the driver of the sensor. I did the next steps, I hope this can fix your issue too:
  • Open the “Device manager”
  • Look for “Biometric devices”, then do a right click on the fingerprint sensor that is not working well.
  • Click on “Uninstall device” and accept the prompt message.
  • Restart your computer. At start-up, windows will detect that fingerpint sensor has no drivers and it will install the most recent ones.
This worked to me, so I hope it does so too for you. Good luck! ;)
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Rishabh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 6,860
