Ir para o conteúdo principal
The Galaxy Watch Active2 is a smartwatch from Samsung Electronics. Its model number is SM-R825, SM-R830, or SM-R835 and was released in August 2019. Repair your Samsung Galaxy Watch Active2 with these guides.
Is it possible to just change the case?
I’ve got a pink version of the watch by accident and they just sit and I can’t do anything with them, because I don’t really want to wear pink watch. Could I just but a broken watch for like 20 bux and change the case by completely reassembling the watch?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I believe this shiuld be possible. The only thing that doesn't seperate from the housing is the rear sensor assembly, so as long as the watch doesn't have a bad rear sensor, you should be fine. Refer to the screen replacement guide for details on how to work on the watch.
Esta resposta foi útil?
Pontuação 2
Related Parts and Tools
Shop all
Adicionar a sua resposta
NeonGooRoo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 12
Ao todo: 497
