Ir para o conteúdo principal
Repair documentation for the 3rd generation 11" iPad Pro (model numbers A2377, A2459, A2301, and A2460).
Does it use the same LCD as 2018/2020
I broke the screen on the m1 ipad pro 11 (2021) and found lcd replacement and was wondering since its meant for the 2018/2020 will it work.
Esta é uma boa pergunta?
Pontuação 2
2 comentários
So a 2020 iPad Pro 11' (2nd gen) screen will work with a 2018 iPad Pro 11 (1st gen) and vice versa?
por
hi
Does it use the same LCD?
ipad prod 11 3 generation model A2377 & A2228?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
No! 1st & 2nd Gen iPad Pro 11” Screen assemblies are compatible with each other but they will not work on the 3rd Gen iPad Pro 11”
Esta resposta foi útil?
Pontuação 3
2 comentários:
O i thought since the screen was the same the assembly was to. Can’t seem to find the 3rd gen anywhere that’s why i asked. Thank you
por
Adicionar a sua resposta
Bakir Subic será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 25
Ao todo: 3,545
