Ir para o conteúdo principal
The Coolpix S7000 was released in 2015. The camera has 20x wide optical zoom, Wi-Fi capabilities, and Near-Field-Communications (NFC).
20 Perguntas Visualizar todos
My camera will not turn on.
The green light shows briefly when turning on then goes off and camera does not open. a new battery has been installed with the same result.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Carefully inspect the contact surfaces of the battery connection in the camera. They may be corroded.
Otherwise, it is likely an internal issue.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Christine Smith será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 6
Ao todo: 316
