Ir para o conteúdo principal
Repair guides and support for the 24" iMac with M1 chip, introduced in April 2021. Identified by model A2438.
20 Perguntas Visualizar todos
How to remove the stand from iMac "24?
Hello,
I going to buy an iMac ‘24 and I thinking to travel with him. I was wondering how I can remove the stand to have more space?
Thank you
Sasha
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
You’ll want the VESA mount model not the standard one if having a removable stand is important Buy the all-new 24" iMac with Built-in VESA Mount Adapter and a VESA stand that works for you.
If you review the iMac M1 24" Teardown as you can see you would need to take your system apart to get to the mounts screws. Which is not practical nor smart!
Esta resposta foi útil?
Pontuação 5
2 comentários:
Thank you so much for your answer! It is not a very smart idea to do it just for that!
por
@saledub Don’t forget to accept the answer - Thanks!
por
Well if you are simply doing to carry it with you often, this is a simplier solution... https://amzn.to/3nG5nJ4 Everytime I bring my imac to apple everyone is complementing me on it...
Now I'm still also looking for a vesa setup though and they do sell clamp on adapters that clamp to the stand itself... some look better than others. I've come across about 3-4 styles. the best looking in my opinion and the one I ordered is the one by viozon as it looks like it was made by apple.
Pontuação 0
Adicionar a sua resposta
Sasa Popovic será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 58
Duração total: 12,542
