Ir para o conteúdo principal
Guides and repair information for Neato robotic vacuum cleaners.
D85 Botvac: clunking noise while operating.
D85 Botvac is working fine, but now has a loud knocking/clunking sound when maneuvering. It is intermittent. I service clean the brush and bearings almost every run. I have tightened up the wheel hubs, so that is not the issue. At a loss.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
So the clunking turned out to be the brush motor becoming loose from the brush gearbox.
I removed the gearbox from the D85 and put blue thread-locker on the motor mount screws. I also added a thin nylon washer between the main transmission gear and the gearbox.
Everything is perfecto now.
Esta resposta foi útil?
Pontuação 0
1 comentário:
where is the gear box
por
Related Parts and Tools
Shop all
Adicionar a sua resposta
Mike será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 256
