iMac 2014 Fan 3000+ RPM on startup
My fan runs at over 3000 rpm on after a cold startup. It is currently running at 3200 RPM with very normal temperatures. CPU 85 C & GPU 67 C
- I have reset the SMC, it doesn’t help
- I have run diagnostic mode, no errors.
- Have even reduced all my processes and removed chrome.
This is a standard Mac (Retina 5K, 27-inch, Late 2014). Never been opened or updated. I doesn’t sit in the sun and is in a cool place.
I have no idea what is, is it the actual fan? Is a just clogged up? Is the fan sensor bad? Thermal Paste?
Want to repair, but don’t know what the problem is.
Esta é uma boa pergunta?
1 comentário
Install this app TG Pro You'll want the full version as you'll want the logging function.
Let it run a few days post a snapshot of the main window making sure you size the window so all of the sensors are visible or take a second snapshot of the lower section after sliding the slider down. Post it and the log file here for us to see Adicionar imagens a uma pergunta já existente
por Dan
