Ir para o conteúdo principal
Repair guides and troubleshooting for the Toshiba Satellite L50-B-2E2 laptop computer.
Boot Loop or What?
**MY LAPTOP IS A L50-C-1FQ BUT I CANNOT FIND IT ON THE DEVICE SEARCH**
Hi there, so I went to power on my laptop and this has happened:
and it does that for as long as it wants.
Background information:
My laptop only powers on when charging and remains at 0% or 1%
I got it on 11 February
1TB hard drive
That is all, thanks.
UPDATE/EDIT: now my laptop does this:
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
That means it’s loading the OS. Could mean anything really. You could try booting into safe mode or whatever. Maybe try disabling secure boot. Could you boot from a usb pendrive and see if you can still see the drive? (maybe clone your disk using clonezilla if you have precious data on it)
Esta resposta foi útil?
Pontuação 0
1 comentário:
Okay, thanks but it has been booting for about 30 minutes I will try those.
por
Switch the ram slots. worked for me.
Pontuação 0
2 comentários:
Okay thank you for suggesting.
por
Hi so I only have one stick of ram (8gb) and one ram slot it seems, thanks for suggesting though ^v^.
por
has it ever booted up? id recommend starting it in safe mode and see if that works.
Pontuação 0
1 comentário:
Hi, thanks for suggesting I will try those now :>
por
Adicionar a sua resposta
Uhmm será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 296
