Ir para o conteúdo principal
A point and shoot camera manufactured in 2014 by Sony.
Camera flap does not close properly
Hi all,
My camera flap could not be closed properly only on the bottom section. Do anyone have any clear solution for this? I had checked if there’s any potential debris and find none as for now. I’m located in Malaysia and couldn’t find any repairer nearby. Hoping this could be solved as been using it for work. Thank you.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi
From the picture it looks like the front of the lens is damaged (lower right corner). It looks like there is a dent there. If this is the case, the flaps might be physically blocked from operating.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
kaibudakbaek será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Ao todo: 140
