Ir para o conteúdo principal
Teardown information for the Nespresso CitiZ coffee machine. They are available from different brands, e.g. Krups, DeLonghi.
Where is the block in the machine?
My Nespresso Citiz stopped making coffee. I descaled it according to directions with descaling powder. I removed airlock using YouTube instructions. The water goes through without a capsule. Once I put a capsule in, there seems to be a blockage and the machine only drips a few drops then stops. I’ve been using a stainless steel reusable capsule for several months now with no problem. I made sure holes in the capsule were not blocked and I also tried putting in less coffee in the pod.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I think I answered my own question. The coffee was ground too fine. I wasted a lot of coffee but I think I finally calibrated my burr grinder to the right setting for espresso. Before I used ground coffee but I just started grinding my own beans.
Esta resposta foi útil?
Pontuação 0
Related Parts and Tools
Adicionar a sua resposta
Helen Atkinson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 359
