Ir para o conteúdo principal
The HP Pavilion 15 cs0xxx is a 15-inch laptop that was released as part of the HP Pavilion computer line.
7 Perguntas Visualizar todos
Where can I get replacement hinges for HP Pavilion 15-cs0051cl?
Where can I get replacement hinges for HP Pavilion 15-cs0051cl??????? I love this laptop, but the hinge on the left is broken and the one on the right isn’t far behind!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If you are looking for just the hinges these appear to be HP Spare Part Number L23884-001. You should be able to order these directly from HP if they have them in stock or you could do a search on Ebay to see if you can find them there as well. It might also be worth picking up a spare set of screws (L23915-001) in case you’re missing some. That could be another reason the hinges are not as tight as they should be.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
jackie12989 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 485
