Ir para o conteúdo principal
Stylus for the iPad Pro (3rd Generation) featuring gesture controls and magnetic attachment and charging. Launched November 2018. Model A2051.
Connected but not working
Hi I have the pencil 2 and an 2020 iPad Pro the pencil has connected to the iPad magnetically and showing on Bluetooth, however the pencil is not doing anything I have tried the following
turn Bluetooth on and off
forgot pencil in Bluetooth and reconnecting
restarting ipad
changed tips
all with no joy. Has anyone any ideas that may help? Thanks
Esta é uma boa pergunta?
Pontuação 13
3 comentários
I have the same issue. Double Tap works but the tip is not responsive.
por
Having the exact same issue
por
Chiming in to the list of people with the same issue. Double tap works. No writing/recognition of the pen on the screen
por
Adicionar um comentário
8 respostas
Pergunta mais útil
I’m having the same issue with my daughter’s pencil. We have several 11 inch iPad Pros in the family. When we connect the pencil to the side of any iPad, the iPads recognize the pencil and can see the status of it’s charge. However, once connected none of the iPads are responding to the pencil in the OS, in Procreate, or in any browser. I know it isn’t a problem with the iPads, because all of the other pencils can be rotated and function with no issues. So it’s definitely an issue with the pencil. We replaced the nib with no luck. I performed a visual comparison between a working 2nd gen Apple Pencil and the subject problem pencil. Nothing stands out as a possible root cause. There are no cracks on the case and all of the conductive material on the tip (under the nib) appears to be intact, including the conductive square on the top. I wish I knew more about the construction of the pencil itself, as I feel this would help me identify root cause. I’ll post again if I can figure anything out.
Esta resposta foi útil?
Pontuação 2
6 comentários:
I’m having the exactly same issue. Like you, I’ve tried everything including new tips. I even notice that the double tap on the side of the pencil works to change from pen to eraser. But the tip does not register contact with the screen. Have you been able to find a resolution? Thanks
por
i am having the same issue the double tap gesture is working but the pencil isn't
por
I know I’m late but I have the exact same problem. If there is anyone who can help me/ us please comment. I really can’t afford to buy a new one right now.
por
Same here. iPad Pro 2020 not connecting with pencil after perfect use for 3 months. So frustrating!!
por
It happened to me today, my Apple pencil 2 stopped working (I am using a 2018 iPad pro). Gets connected, no physical damage, double tap not working, tip change also didn't help. From all the comments above, it seems there is no solution at all.
por
Exibir mais 1 comentário
To date, the second Apple Pencil only works with the 11-inch iPad Pro and third-generation 12.9-inch iPad Pro.
Firstly check out if the 2nd generation Apple Pencil works with your iPad.
https://support.apple.com/en-us/HT211029
Go into settings and make sure Bluetooth is turned off. Plug in pencil and quickly turn on Bluetooth. The pad must recognize the pencil from settings instead of the pop up box.
Pontuação 0
Hi - I know you already tried forgetting device and restarting iPad, I tried that several ways and it didn’t work for me either, but when I did it a very specific way, it finally worked. I’m not sure if all of these steps are necessary, but try it.
1) forget Apple Pencil device under iPadOS settings—>Bluetooth
2) Turn Bluetooth off, then ON again. I Don’t think it matters if pencil is attached or not, but feel free to try it either way.
2) set pencil on magnetic surface of ipad if its not there already (it might say “Apple Pencil” but no charging percentage, thats okay). Make sure you leave it there for a few minutes just in case its charging without you knowing it.
3) turn off iPad by holding top button and volume up side button then sliding the screen button slider to power off.
4) turn iPad back on by holding top iPad button
5) For me, after putting in my passcode, the iPad recognized the pencil attached and the indicator finally said “40% Apple Pencil” and it worked again.
I was close to buying a new one due to all the reports of lithium ion battery irreplaceability and other instructions not working for me. Glad i didn’t.
Pontuação 0
1 comentário:
Update - it did work for awhile, but then my parents’ dog grabbed it and chewed it to bits when i visited.[image|2463794]
por
I tried this method as well as all the others. Still does not want to interact for me. Glad you were able to get yours to work!
Pontuação 0
I was having this exact problem! I got my iPad two days ago and I’ve playing around with it and everything has been working fine. But then today suddenly the pencil wasn’t working even though it was charged 100%. I restarted the iPad multiple times and still nothing. Finally, I realized the nib had been slightly unscrewed. Once I tightened it, everything worked fine lol. I’m not sure how it became unscrewed between me putting the iPad down last night, going to bed, and then trying to use it again this morning, but it seems like that’s all that was wrong!
Pontuação 0
Hey all- I thought I followed up on this but I don’t see my follow up. I ended up making a Genius Bar appointment using my daughter’s iPad info. There was a step that asked me to specify what was wrong and one of the choices was “Accessories“ or “Peripherals” (can’t remember the exact wording.) I chose that. Her dad ended up taking her so I’m not sure if there were inspection or troubleshooting steps, but they completely replaced the pencil. So bottom line is I’m still not sure what the root cause of the problem is, but hopefully you can do the same and get a working pencil replacement!
Pontuação 0
1 comentário:
Same situation here. But Genius Bar only offered a 20% discount for a "Genius Bar swap" for a new Pencil :(
por
I have the exact problem and just learned today that the transducer is damaged or broken, which is the little goldish looking thing underneath the pencil tip
Pontuação 0
1 comentário:
Good to know! Is it replaceable?
por
Well, my "broke" today as well. The battery works fine and attaches to Bluetooth with no problem. It just won't draw. What a bummer.
Pontuação 0
Adicionar a sua resposta
Kyber será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 67
Últimos 30 dias: 270
Ao todo: 16,113
