Ir para o conteúdo principal
The Toshiba Satellite E45-B4100 laptop was put to market on March 4th, 2015. It has a 14 inch screen and weighs 6.8 pounds. The model number is PSPNAU-001002.
Replace CPU on this model
I am having trouble removing the factory CPU for this model. I does not have a screw latch as older models. It seems to be surface mount. If this is the case, what is the safest way of removing this CPU and replacing with another? Thank you so much! This is part of a major project I am working on and would be great if I can get passed this road block!, Again, thank you so much!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I believe this cpu is soldered on
Esta resposta foi útil?
Pontuação 0
Related Parts and Tools
Adicionar a sua resposta
Jean Mesa será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 171
