Ir para o conteúdo principal
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
View button not responsive
I have a camo 1708 controller with a view button that does not work. Tested via the Accessories app, updated the firmware, plugged it into the console. All the button work except for the view button. What do I need to replace?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Actually, you might fix it by cleaning it if you are lucky. Otherwise, I would try to change the conductive pad. Here is a video where I had a similar problem and that cleaning worked really well : https://youtu.be/yilEo_n_364
Esta resposta foi útil?
Pontuação 1
1 comentário:
Had the same issue on a brand new controller that i was too lazy to send back.
I fixed it today by just cleaning the pad with a good squeeze. (It was all good all clean but after putting my thumb in and scratch it a little it works nice, dunno why but it's fixed now)
por
Adicionar a sua resposta
jamincash será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 328
