Ir para o conteúdo principal
The Samsung Gear S3 is the third-generation Samsung Gear smartwatch, first released in November of 2016. Features a round OLED display running the Tizen OS. Model number: SM-R770NZSAXAR.
67 Perguntas Visualizar todos
How easy is it to strip out the screws; I have the right driver...
I'm trying to change out the back of my watch because the glass is cracked, but I have a feeling I may might have at least partially stripped the screws even though I have the right driver… How easy is it to strip them, and how would I go about removing them if they are?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I can tell you that very easy. It seems that they use a locking glue and sometimes they may have been over screwed making them more difficult to unscrew with the result you have seen. I striped 2 , the other 2 got out easily. So even with a good tool, it will happen. I am waiting for tools to take both out, and ordered 4 new screws. Will see if I have success. The screws are flat inside, if your special screwdriver has a point that could be a problem. Mine is flat point but even with that type two of the screws did not came out. Good luck.
Esta resposta foi útil?
Pontuação 0
1 comentário:
what tools did you use? Did you manage to remove the stripped ones? Thanks
por
Adicionar a sua resposta
KopaGeek será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 330
