Ir para o conteúdo principal
Xiaomi-owned Amazfit's square, plastic smartwatch. Released in 2017.
16 Perguntas Visualizar todos
Screen fell off - what can I use to reattach?
The screen of my Amazfit Bip just fell off. I removed the old adhesive strip and tried a small bead of clear silicone seal. This didn’t work. What can I use to reattach the screen?
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
2 respostas
I used B7000 glue for mine, it works good for stuff like this. Although for me it still fell off again after several month :) I fixed it again, but in the end I just upgrade to Amazfit BIP 2 recently.
Esta resposta foi útil?
Pontuação 0
Mine just fell off as well. I’ve had it for over two years. I inspected it, and realized that it looked like the seal for the display has been de-laminating for quite a while! I am thankful I didn’t wear it while showering, or doing things while around splashing water. It woud have surely damaged it. I carefully scraped all the junk that had accumulated around the edge of the display, and around the watch casing groove for the display was. I used “shoe goo” as the glue. It supposedly has some water resistant properties. Hopefully it will work for a while.
Pontuação 0
Adicionar a sua resposta
William Anderson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 33
Duração total: 2,757
