Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1863, A1905. Disponível com GSM ou CDMA / 64 ou 256 GB / Dourado, Prateado e Cinza Espacial.
iPhone 8 bootloop when plugged in
I replaced a broken screen on an iPhone 8, after doing so it was stuck on a bootloop.
Nothing was changed except of the screen but I did remove some gunk from the charging port. When unplugged it showed a low battery symbol but when plugged in it was on an infinite bootloop.
I replaced the dock connector but with the same result: low battery symbol with lightning connector, when plugged in it briefly shows just the low battery symbol and after a while it goes on bootloop.
I think it just doesn’t have enough power to boot and maybe the battery is broken (seems strange though because before the screen was broken it worked fine).
someone told me it might be a motherboard problem because it doesn’t show up on iTunes either?
Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
If it’s in a bootloop get it in recovery mode and try updating on 3UTools / iTunes.
Esta resposta foi útil?
Pontuação 1
6 comentários:
I can't find the device on my computer (iMac mac os high sierra).
por
Once I get home I'll post instructions on how to put it in recovery mode it's pretty tricky on the iPhone 8.
Holding the side button while plugged in should be enough to kick it in recovery mode.
por
I can get it in recovery mode, it just doesn't show up on iTunes.
por
It can't charge nor make connection with a computer...
por
Can I ask if you fixed the issue? and what the problem was?
por
Exibir mais 1 comentário
Try disconnecting the earpiece (earspeaker) cable and try again.
Pontuação 0
Adicionar a sua resposta
Rembert será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 349
