Ir para o conteúdo principal
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
Soldering charging flex cable to ipad 5
My ipad 5th generation wasn’t charging. So I read about soldering on another flex cable. The problem is before I read the instructions I ripped off the old flex cable. Now on the logic board there are no ribbons to solder on the new cable.
Is it time to retire the logic board or is there a way I can revive it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You need to follow the traces and solder jumpers. It takes a lot of skill. If you don't know how to microsolder I would recommend taking it to a repair shop.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Daniel Roszhart será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 86
