Ir para o conteúdo principal
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
stuck on the galaxy s6 powered by android screen.
I have the same problem, One day my S6 SM920F just went off and never wanted to boot again. It just stuck on the galaxy s6 powered by android screen. Installed a firmware around 6 times and also installed TWRP Recovory but still was stuck on the screen. I don’t know how to fix it.
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Sadly I have the same problem. Nothing seems to fix it. It was working a few days ago. Turned it off and left it on my desk and came back the next day to turn it on and it's been stuck ever since.
por
Adicionar um comentário
1 resposta
Hi there!
Try deleting clearing cache. Here is how to do it
  1. Turn off the phone.
  2. Press and then hold the Home and Volume UP keys, then press and hold the Power key.
  3. When the Samsung Galaxy S6 shows on the screen, release the Power key but continue holding the Home and Volume Up keys.
  4. When the Android logo shows, you may release both keys and leave the phone be for about 30 to 60 seconds.
  5. Using the Volume Down key, navigate through the options, and highlight ‘wipe cache partition.’
  6. Once highlighted, you may press the Power key to select it.
  7. Now highlight the option ‘Yes’ using the Volume Down key and press the Power button to select it.
  8. Wait until your phone is finished wiping the cache partition. Once completed, highlight the ‘Reboot system now’ and press the Power key.
  9. The phone will now reboot longer than usual.
  10. Hope this helps!
Esta resposta foi útil?
Pontuação 0
1 comentário:
i tried all this but no deal
por
Adicionar a sua resposta
Dilan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 47
Ao todo: 5,069
