Ir para o conteúdo principal
The Hisense Chromebook C11 is a 16 GB Chromebook with 2 GB of RAM, produced by Hisense.
Captive portal internet traffic blocked
I can only go to 2 different sights it says it has blocked traffic on the internet
Esta é uma boa pergunta?
Pontuação 0
1 comentário
My captive portale somehow got turned on. I didn't know of this issue before, so I thought I could fix it by resetting my 11e chromebook, but it did not work and I don't know what to do. Any help?
por
Adicionar um comentário
2 respostas
Solução escolhida
Try this:
You have to get the captive portal page to display. Try these tricks first:
  • Close all open tabs in your browser. If you have a secure site open ( https:// ), the portal can get confused. Close everything in your browser. If you have your startup setting “Continue where you left off”, then change it to “Open the new tab page” and open your browser again. If you don’t see the captive portal come up, try going to a http:// website as they can trigger the captive portal.
  • If you are in a hotel you may need to log into the captive portal after a period of time to continue using the internet. This will force you to go through the whole thing again.
These are all temporary solutions and not the most convenient ones. You may want to raise a complaint to your ISP or if you are staying at a hotel you may want to bring it up to the management as this is an ISP issue.
And if you are using a VPN the only way to connect through a captive portal is to turn it off. Unless you are using Speedify bonding VPN.
Esta resposta foi útil?
Pontuação 1
My t-mobile Hotspot was turning on my captive portale. Took my computer to a computer doctor.
Pontuação 0
Adicionar a sua resposta
whiterose9us será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 2,036
