Ir para o conteúdo principal
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
Why is there a spot that seems to click by itself?
The screen is loose I can feel it move. If I try I can pull it away from the unit kinda easy. Lately it has a spot on the screen that seems to click by itself. what needs done? I dont see and visible cracks in the screen.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
If the screen is separating on it’s own, it could be a few things such as a warped frame from impacts, a swollen battery, or a poor repair job. Can you post some pictures to help me determine what the issue could be?
Esta resposta foi útil?
Pontuação 0
I took a pic of the separation. Also, theres a part of a ribbon cable protruding out that I thought was a piece of adhesive.
Pontuação 0
Adicionar a sua resposta
James Lattanzi II será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 69
