Ir para o conteúdo principal
The Toshiba Satellite Radius is a two in one PC allowing the users the benefits of both a tablet and laptop. The device comes with a fourteen-inch screen and a ten-point touchscreen. Model number: E45W-C4200X
How to replace the hinges on the laptop?
My laptop fell and it no longer flips all the way around I can get it to go to 50 degrees but nothing more. Any steps for replacing/repairing the hinges?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
There’s did a Broken Toshiba Laptop Hinge provided by https://www.instructables.com.
Basically, in that tutorial, you’ll need some tools, including:
  • Cordless Drill
  • Drill Index
  • Hacksaw
  • 3 mm coupling nuts
  • 3 mm short screws
  • Small Screwdrivers
  • Vicegrips or vice
Check out your computer and make sure choosing the right tools.
I think a video will better guide you every step of the repair.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Alecia Millings será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 207
